Guest Captive portal over cellular data
  • 1.  Guest Captive portal over cellular data
    Posted Oct 28, 2019 04:19 PM
    We have our guest network set up with a captive portal.  Not every device auto-redirects to the captive portal so we set up an internal web page that users can manually go to "go.domain.net".
    We are running into devices that use the "prefer best connection" type of setting though.  So they "connect" to the Guest SSID but since they have no connection their device routes over their cell connection.  Does anyone know of a good way to force devices to use the wireless connection?
  • 2.  RE: Guest Captive portal over cellular data
    Posted Oct 28, 2019 08:27 PM
    There is nothing that can be done from the infrastructure perspective. It is a client decision.
  • 3.  RE: Guest Captive portal over cellular data
    Posted Oct 29, 2019 09:53 AM
    Thats what I thought, just wanted to make sure we weren't missing anything.
    Thank you
