I'm currently developing a guest captive portal that redirects to a terms and conditions checkbox to provide anonymous public access login, with an optional hyperlink to an separate web login page with a username/password combination for contractor access (the customer's design). Surprisingly, I couldn't find any examples, or similar forum posts, in my searches, but had assumed this was a simple process of adding in the hyperlink to the header HTML code of the default anonymous Web Login page pointing to the URL of the alternate user/pass Web Login page. To clarify, I've created two separate Web Login pages to accomplish this in Clearpass Guest.
This links work perfectly fine when I test it directly from internal networks, but when I have the customer test onsite from the guest SSID, apparently clicking on the link only cycles back to the original anonymous web login page with an "error connecting" message.
The NAD is an Instant AP.
I'm currently just looking to determine whether this is even possible (I assume it should be), and if I'm missing anything obvious in how to link to the alternate Web Login page. I assume there must be some way for Clearpass to maintain the information of the connecting client and NAD device, so possibly something needs to be included in the HTML (or JS?) to carry over this information between the web login pages?
Cheers!
