Guest Captive Portal with Pin Confirmation
  • 1.  Guest Captive Portal with Pin Confirmation
    Posted Apr 26, 2021 12:06 PM
    Hello guys,
    We are rolling out Aruba AP's with Clearpass for the first time and would like to have guests register their number and send them a Pin which they will have to enter to login.
    By default the users are getting logged straight in.
    Are you able to advise a way to get this solution working please?
    Sentan Yaso
  • 2.  RE: Guest Captive Portal with Pin Confirmation
    MVP GURU
    Posted Apr 27, 2021 06:35 AM
    by PIN, do you want a password for guest ?
    and there is a option to don't automatically logon
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Guest Captive Portal with Pin Confirmation
    Posted May 04, 2021 10:34 AM
    If you work for an Aruba partner, check this page on Arubapedia for Partners. Or reach out to your Aruba partner.
