Guest login for each AP group
  • 1.  Guest login for each AP group
    Posted Dec 09, 2015 03:36 AM
    We have offices/schools in many several location. Today we create a single guest login (username and password in the controller (security ->Internal DB with role, guest) for each location.
    Problem for us now is that users login to guest network using a different locations username and password. They get the username and pasword for another loaction, than ment for the loaction they are in.
    We would like to prevent this from happening, so how can we configure a uniq login for each AP gruop that we hva in the controller.
    WLC:
    Model:        Aruba7240
    Version:      6.4.2.6
    Compiled:    2015-04-16 at 14:19:48 PDT (build 49665) by p4build
    Thnaks for any input/answer....
  • 2.  RE: Guest login for each AP group
    Posted Dec 09, 2015 05:27 AM
    In order to do this you will need a policy server like ClearPass to make that decision and the Guest module for the captive portal
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Guest login for each AP group
    Posted Dec 09, 2015 05:33 AM
    Is there no way to set a unique guest username and password for different AP groups?
  • 4.  RE: Guest login for each AP group
    Posted Dec 09, 2015 05:52 AM
    The issue is that you are using the same controller internal database and there's no way to prevent the user in the DB from authenticating to that particular page assigned to the AP-GROUP.
    Thank you
    Victor Fabian
  • 5.  RE: Guest login for each AP group
    Posted Dec 09, 2015 07:24 AM
    Thank you
    Victor Fabian
    Ok, I understand. Thank you for your answers...
