I don't remember seeing such a page before. It looks like there is an external device, firewall or so, that implements the captive portal. The reference to Java indicates that it's really old and probably vulnerable/insecure.
Maybe you can see the URL for the page somewhere? From there find out what is showing the captive portal?
And/or check the role that the user is in, with redirects and other information. On the controller CLI: show users (check the role for the guest user), then 'show rights xxxxx' where you replace xxxxx with the role that the guest user is in.
Original Message:
Sent: Aug 27, 2024 06:05 AM
Subject: Guest Login Page Design
Original Message:
Sent: Aug 27, 2024 05:40 AM
Can you share a screenshot of that guest page?
If it's the built-in controller page, check here for instructions on how to customize. With an external captive portal you would have more flexibility and features, but if you can keep it simple the internal page may work for you. Aruba Central won't be an option for controllers running 8.10 firmware, unless you upgrade to AOS 10.
Original Message:
Sent: Aug 27, 2024 04:20 AM
I am using Aruba7205, 8.10.0.6 on Windows 10. I have a guest wifi. After selecting the guest WIFI, it promts to a page that requires login credentials to access the internet. I would like to edit this page. Or would like to create a page that could replace this. I am confused whether I can do it without having clearpass or aruba central.
Original Message:
Sent: Aug 27, 2024 04:13 AM
Which Guest Login page are you referring to? There are at least 4 options in the Aruba portfolio, and magnitudes externally.
Please describe the equipment, version, captive portal in use (or planned to use)?
Original Message:
Sent: Aug 27, 2024 03:08 AM
I am willing to change the guest login page. I have no access to aruba central. With Aruba mobility controller, is there any possibility to update the page?
Could anyone please help me out here?
