Guest Login - Redirect on Failure
  • 1.  Guest Login - Redirect on Failure
    MVP
    Posted Jun 29, 2016 11:20 AM
    Hey everyone,
    Trying to setup a captive portal page on CP Guest, that if a guest user tries to login with thier credentials, but fail, it redirects to a page that says "Login Has Failed, Please click here <link> to try again or contact the network admin". Basically we don't want them kicked back to the same page. Is this possible to do?
    Thanks.
  • 2.  RE: Guest Login - Redirect on Failure
    Posted Jun 29, 2016 12:39 PM
    Beginning with ArubaOS 6.5, that is supported by setting the "Reply-Message" radius attribute in the radius reply:
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=22044
  • 3.  RE: Guest Login - Redirect on Failure
    Posted Jun 29, 2016 12:55 PM
    Examples of how it looks:
    Internal Captive Portal rejected:
    Internal Captive Portal Passed:
    External Captive Portal Rejected:
    External Captive Portal, Passed:
  • 4.  RE: Guest Login - Redirect on Failure
    MVP
    Posted Jun 29, 2016 01:20 PM
    Interesting, however, we were trying to do something a little more complicated, but to make it simple I tried to give that example. We needed a new page upon failed authentication, but I was able to change it so the authentications succeeded. We are all good now.
