Guest Login with Twitter
  • 1.  Guest Login with Twitter
    Posted Oct 23, 2014 09:19 AM
    I am trying to get the social network login working with Instant and ClearPass Guest.
    I already set up Facebook and LinkedIn without any problem, but not Twitter. I don't know why, but everytime I try to click on the button, I am instantly redirected to the captive portal, as if it was only refreshing the page...
    To be sure that's it's not due to a firewall rule problem, I tested using the login page when being on a network with full access. Facebook and LinkedIn work, but not Twitter...
    Any help would be appreciated.
    - nice2k.
  • 2.  RE: Guest Login with Twitter
    Posted Oct 23, 2014 09:38 AM
    Do you have these whitelisted ?
  • 3.  RE: Guest Login with Twitter
    Posted Oct 23, 2014 09:45 AM
    Thank you for your reply.
    Yes, I whitelisted all of these 3 domains. And to be sure that it is not a fw blocking problem, I launched the login page from this link using a network where I have all access :
  • 4.  RE: Guest Login with Twitter
    Posted Oct 23, 2014 10:12 AM
    Did you defined the following in the Twitter App?
    And use the right credentials:
  • 5.  RE: Guest Login with Twitter
    Posted Oct 23, 2014 10:20 AM
    Yes, that's what I did ! Except the URL of the page where I put the login page instead :
    https://xxxxx/guest/Aquastar_login.php
    I really don't see why everything works with the others and not with Twitter...
  • 6.  RE: Guest Login with Twitter
    Posted Oct 23, 2014 11:05 AM
    Interesting...sounds like a FW issue
  • 7.  RE: Guest Login with Twitter
    Posted Oct 24, 2014 04:18 AM
    I can't see how :(
  • 8.  RE: Guest Login with Twitter
    Posted Oct 24, 2014 04:21 AM
    You need to Tripple check your URL setting in Twitters app setup page. Usually when that happens the post back to CPPM is not correct or as victor mentioned it's a firewall issue.
  • 9.  RE: Guest Login with Twitter
    Posted Oct 24, 2014 04:53 AM
    Thanks for your help.
    I triple checked my URL login in the Twitter App, it is good. I'm on the network login page with the buttons when I click on it.
    I don't understand how it can be a FW issue since I can navigate without any problem on twitter, api.twitter.com, etc...
  • 10.  RE: Guest Login with Twitter
    Posted Nov 07, 2014 05:10 AM
    WOW. Finally solved this problem !!
    I was using an auto-register page for guests and when I was trying to click on the Twitter login page, nothing was happening. It was just like it was refreshing the portal.
    So, I tried to create a Web Login page instead, and when I tested i got an error :
    "Desktop applications only support the oauth_callback value 'oob'"
    Figured out that it was because I left the Callback URL field blank on my Twitter App...
    This HAS to be non-empty
    I put "https://example.com" only to have something in there and everything worked perfectly.
    After several weeks of scratching my head, I'm happy I found what was going on and hope it will help others that are trying to implement Twitter for their guest login.
    - nice2k
