Guest login with username only - bulk imported users
  • 1.  Guest login with username only - bulk imported users
    Posted Jun 03, 2015 10:57 PM
     Hi All,
    Looking for some guidance as i'm not too great with the custom login forms in ClearPass.
    I'm working on an install where the customer wants to import a list of ID numbers (client ID's) and then have a login form that only requests the ID numbers.
    I was thinking along the lines of importing the userids using the bulk import tool and defining both username and password as "userid" and then creating a custom form that takes the userid and submits this as both user id and password.
    any ideas how i could pull this off?
    I have also considered the access code method but this doesnt' allow me to define the "authenticate_user" field during the bulk import. trying to keep it simple for the customer.
    Scott
  • 2.  RE: Guest login with username only - bulk imported users
  • 3.  RE: Guest login with username only - bulk imported users
    Posted Jun 08, 2015 06:33 PM
    Hi Victor,
    Thanks for sharing the link.
    Not quite what i'm looking at. I've got an access code based login page working. The catch is i want to do regular import of the access codes (client  number).
    The issue i'm having is that the flag needed for the user account (username_auth) can't be modified on import but rather needs to be bulk edited after the fact.
    working with the TAC to come up with something now
    Scott
  • 4.  RE: Guest login with username only - bulk imported users
    Posted Jul 09, 2015 06:08 PM
    Only special accounts get past the web logins with Access Code enabled.  Specifically the guest account needs the username_auth field set.  You control any attribute in an import by ensuring you have the proper header row.  So at a minimum you would want:
    username,username_auth,enabled
    user1,1,1
    user2,1,1
    The import (Guest > Import Accounts) will detect the fields in the header row and automatically generate the password.
    A similar, and often overlooked feature is our pre-registration flag.  Change the enabled values to 0 to force disabled.  Create a self-registration and enable username on the main registration form.  Edit username and at the bottom within the Advanced section is Pre-Registration.  Check this and save.  The self-registration now requires that field to match an existing entry.  This allows you to give codes our but also ask for additional information like name, company, or whatever.
  • 5.  RE: Guest login with username only - bulk imported users
    Posted Jul 09, 2015 07:09 PM
    thanks gbenedict, this is exactly what i needed, i didn't realise that i could import any named attribute on the form!
    This is excellent!
