Guest MAC authentication error
  • 1.  Guest MAC authentication error
    Posted May 24, 2018 10:15 AM
    Im seeing this in the logs when guest users are trying to MAC authenticate:
    It says unknow client, but when checking endpoint repository, I see this:
    This is found when searching the repo with the MAC address of the client.
    I have just changed CP install from a old Dell branded CP, to orgininal Aruba CP. This error was also present on the old unit.
    Can anyone help me with this.
    Thanx
    J.
  • 2.  RE: Guest MAC authentication error
    Posted May 24, 2018 10:17 AM
    You should be using [Allow All MAC Auth] as the auth method.
  • 3.  RE: Guest MAC authentication error
    Posted May 25, 2018 04:12 AM
    I have tried out this method, alot of requests go through, some dont.
    Why does MAC-AUTH say the klient is unknown, when its know ?
    The MAC-AUTH setting follow the guest template on  6.7.3.106273
    Just wondering.
  • 4.  RE: Guest MAC authentication error
    MVP EXPERT
    Posted May 25, 2018 12:54 PM
    Your endpoint in the endpointdatabase must have a “known device” status to use mac-auth.
  • 5.  RE: Guest MAC authentication error
    Posted May 25, 2018 12:56 PM
    That is not correct. Allow All MAC Auth should be used and handle everything in authorization. Known/Unknown is not required.
  • 6.  RE: Guest MAC authentication error
    Posted May 25, 2018 01:15 PM
    One of my local contacts in norway tells me that they use only MAC-AUTH since this is the template default.
    It also doenst explain to me why the MAC-AUTH fail on know devices with valid attributes.
  • 7.  RE: Guest MAC authentication error
    Posted May 25, 2018 01:19 PM
    Use Allow All MAC Auth.
