Guest Management user not able to SSH to Aruba IAP-225
  • 1.  Guest Management user not able to SSH to Aruba IAP-225
    Posted May 02, 2016 02:38 AM
    Folks,
    I seem to need some help with the Aruba-IAP configuration. The guest management username which we have created for Guest registration only is not able to SSH to the controller.
    Is this again a feature limitation or there is something which is not enabled.
    Neel
  • 2.  RE: Guest Management user not able to SSH to Aruba IAP-225
    Posted May 02, 2016 01:39 PM
    a guest-mgmt user would not be able to SSH into IAP and it does not need to. It can create the visitor accounts using GUI.
