Guest - multiple login methods?
  • 1.  Guest - multiple login methods?
    Posted Oct 13, 2017 01:04 PM
    Question around Guest and using multiple access methods within the same SSID.
    I have a client looking to deploy Guest with multiple access methods based on the 3 main Guest roles:
    -Guest - simple click-through anonymous portal with AUP acceptance
    -Employee - AD authenticated w/ AUP acceptance
    -Contractor - Guest DB authenticated with AUP acceptance
    Hardware is Cisco WLC.
    All 3 are reasonably easy on their own, but my idea was to insert a link on the basic guest landing page to a secondary page which prompts for credentials, and then logging in that way.  Doing this and clicking it will load the secondary page, but I lose all endpoint information/other parameters present on the URL that comes from the initial redirect, and then my authentication requests don't hit my user authentication service. Is a pre-auth check required for the latter 2 roles? I'm not entirely sure on the recommended pre-auth check to use, if that's the case.
    Thanks in advance,
    Tim
