Aruba Central
Guest Network
This thread has been viewed 35 times
  • 1.  Guest Network
    Posted Mar 07, 2023 02:50 PM
    We have a Guest Network set up using captive portal and aruba central for authorization.  Its has been fine for our visitors but we just added another site that is part of our company and they have some devices like thermostats that need connected and was wondering if there was a way to have both the captive portal and mac authorization?
    Thank you
  • 2.  RE: Guest Network
    MVP GURU
    Posted Mar 08, 2023 07:32 AM
    You can, and this is how guest auth with mac caching works. You have to open advanced settings, and turn MAC auth on. It will use the servers set in the security profile.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: Guest Network
    Posted Mar 08, 2023 07:53 AM
    Dustin,
    That doesn't show up under my guest set up.  Here is what I see.
  • 4.  RE: Guest Network
    MVP GURU
    Posted Mar 08, 2023 08:11 AM
    Ahh yes, its not available when you are running cloud guest instead of an external server.
    Dustin Burns
  • 5.  RE: Guest Network
    Posted Mar 08, 2023 08:17 AM
    Gotcha, Thank you for the update.  I will look at setting up an external captive portal.
