Guest Network and Accessing Public Web Sites Hosted Internally
  • 1.  Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 15, 2017 11:50 AM
    We have a guest network configured exactly as described in Aruba's literatire found here. It works great but when connected to it, we are unable to access any web site, hosted internally, that is available publically.
    Has anyone else come across this?
  • 2.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    Posted Feb 16, 2017 05:05 AM
    EDIT: Oops I misread your post.
    I've seend this before. In the scenario I had the firewall didn't know how to route the guest traffic to the sites. Have you got the firewall setup to allow Guest --> External site IP --> Internal site IP --> External Site IP - Guest?
  • 3.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 06:46 AM
    JAmes,
    Thanks for the response. I have our guest network on the controller configured exactly as described in Aruba's documentation. What changes can I make to get this to work? I'm not sure if I understand what you mean.
  • 4.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    Posted Feb 16, 2017 06:50 AM
    What exactly is happening?
    Are the guest able to resolve the DNS name of your site? What does it resolve to (internal or external IP)?
  • 5.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 07:07 AM
    Guest users are not able to ping or access any of our external sites and IPs. They can access any Internet site except for the sites that exist internally alongside the controller. It seems as if the guest VLAN on the controller doesn't have access to the external IPs of our internal sites. It tries to resolve the external IPs, not internal, which I would assume is correct, but can't.
    There are no specific rules on the controller's firewall that I can see that's restricting this.
  • 6.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    Posted Feb 16, 2017 07:43 AM
    I'm confused by your response.
    Can we clear this up...
    1. If you ping one of the websites external DNS names, does it resolve it to an IP address?
    2. If yes for question 1. Does it resolve to the external IP address?
  • 7.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 07:58 AM
    Sorry for the confusion.
    1. No. If I ping one of our external DNS names, it attempts to ping the external IP, not the intenal, but it's unable to contact it and times out.
  • 8.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    Posted Feb 16, 2017 08:01 AM
    No worries.
    Ok, so DNS is working and resolving to the correct IP addresses. I believe, the issue is likely going to be firewall related. Can you check your firewall to see if it's dropping/blocking this traffic?
    I would try setting up a continuous ping to one of the sites then check the firewall for this traffic.
  • 9.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 08:03 AM
    The firewall on the controller, our site's firewall, or both?
  • 10.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    Your site firewall. :)
  • 11.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 08:30 AM
    Nope nothing on the firewall. I'm inclined to think that the issue is on the controller, just not sure where to look as of yet.
  • 12.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    Posted Feb 16, 2017 08:34 AM
    Try browsing to the site and checking the "site firewall". ICMP is probably not allowed by your guest role.
  • 13.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 08:46 AM
    You're correct. It looks like ICMP is not currently included in any of the roles. I can see traffic on our firewall generated when navigating to an accessible site, such as CNN.com, but if I attempt to navigate to one of our external IPs, there's nothing on the firewall. That leads me to believe that the traffic is not leaving the controller.
  • 14.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    Posted Feb 16, 2017 08:52 AM
    Ok. What are the firewall rules on the role that your guest user is on?
    You can run #show rights <guest role> to find them.
    Also try the following. Attempt to browse to on of the sites. Then immediately on the CLI do the following:
    #show datapath session table <external site IP>
    ..where <external site IP> is the IP address of the website you're trying to access. Then post the result back here.
    Here's some details about this command.
    It will show if the traffic is being blocked on the controller.
  • 15.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 09:00 AM
    (Aruba7210) #show rights auth-guest
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'auth-guest'
    Up BW:No Limit   Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Number of users referencing it = 1
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    Youtube education: Disabled
    Web Content Classification: Enabled
    ACL Number = 94/0
    Max Sessions = 65535
    Check CP Profile for Accounting = TRUE
    Application Exception List
    Name  Type
    Application BW-Contract List
    Name  Type  BW Contract  Id  Direction
    access-list List
    Position  Name                   Type     Location
    1         global-sacl            session
    2         apprf-auth-guest-sacl  session
    3         cplogout               session
    4         guest-logon-access     session
    5         block-internal-access  session
    6         auth-guest-access      session
    7         drop-and-log           session
    global-sacl
    Priority  Source  Destination  Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6  Contract
    cplogout
    1         user    controller   svc-https               dst-nat 8081                           Low                                                           4
    guest-logon-access
    1         user    any          udp 68                 deny                             Low                                                           4
    2         any     any          svc-dhcp               permit                           Low                                                           4
    3         user    Public-DNS   svc-dns                permit                           Low                                                           4
    1         user    Internal-Network  any                   deny                             Low                                                           4
    auth-guest-access
    1         user    any          svc-http                permit                           Low                                                           4
    2         user    any          svc-https               permit                           Low                                                           4
    drop-and-log
    1         user    any          any                   deny               Yes           Low                                                           4
    AND
    (Aruba7210) #show datapath session table 216.37.255.6
           Q - Real-Time Quality analysis
           E - Media Deep Inspect, G - media signal
           r - Route Nexthop
           A - Application Firewall Inspect
    Source IP       Destination IP  Prot SPort DPort  Cntr    Prio ToS Age Destination TAge Packets    Bytes      Flags
    192.168.200.174 [EXTERNAL IP]    6    50616 80     0/0     0    24  0   tunnel 1167 3    4          256        SYTC
    [EXTERNAL IP]   10.0.0.101      6    80    50616  0/0     0    24  0   tunnel 1167 3    0          0          NY
  • 16.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    Posted Feb 16, 2017 09:10 AM
    So you're using source NAT on the traffic leaving the guest network.On your site firewall you should see the traffic attempting to get to 216.37.255.6 from your controllers IP address.
    The outputs formthe show datapath command show that it'snot being blocked on the controller.
    Is 10.0.0.101 the controller?
    (let me know if you want me to remove your IP addresses from this post)
  • 17.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 09:31 AM
    Yes 10.0.0.101 is the controller. There's got to be something on our firewall that's preventing this but I'm not seeing the traffic as of yet. Unfortunately, my boss who administers the firewall is out today and I'll speak with him.
  • 18.  RE: Guest Network and Accessing Public Web Sites Hosted Internally
    MVP
    Posted Feb 16, 2017 09:42 AM
    Yes if you can remove our external IP, I'd appreciate it. Thanks again.
