Guest network not working as expected
  • 1.  Guest network not working as expected
    Posted Dec 11, 2012 06:35 AM
    Hi, I have 4x IAP105 accesspoints. I enabled the guest access with separate SSID and role based policies. Here are the details:
    Primary usage: Guest
    Vlan: VC assigned
    Security:
      Splashpage : Internal authenticated
      Auth Server: Internal Server
      Re Auth Interval : 30 Mnts
      Internal server: 2 users
    Access:
      Http-Access to all dest.
      Https-Access to all dest.
      DNS-access to all dest.
      any-deny-to all dest.
    So, to my question now. My goal is to protect the guest looking at my internal network. They only required to browse the internet. They should not ping, telnet, search servers etc. And they should receive authentication screen before browsing started.
    But, now, with above configuration, they are able to use the outlook, they can browse the internet without authentication! but they cannot ping to the servers, thats good. I am surprised why the authentication screen dont display to them.
    Please let me know what is the best practice for the guest network and what access policies should define and what is the order of the policy placement.
    Thanks for your support.
  • 2.  RE: Guest network not working as expected
    Posted Dec 11, 2012 08:41 AM
    You are doing the policy incorrectly
    Look
    Withyour policy you are allowing http access to all the internal servers
    dns access to all internal servers and also https access to all internal servers
    The rule should be like this
    Let say your internal networks are
    192.168.1.0/24
    192.168.2.0/24
    192.168.3.0/24
    all access deny  to 192.168.1.0/24
    all access deny  to 192.168.2.0/24
    all access deny  to 192.168.3.0/24
    all access allow dns to all destination
    all access allow http to all destination
    all access allow https to all destination
    That if you just want to allow access to http https and dns to the internet
    Now remenber that if you got a webfilter and the ip address of the AP is the one that you need to use.... i dont know if you understand this part?
    You need to use the IP addresses of the APs to use the webfilter correctly.
