Guest not access to captive portal
  • 1.  Guest not access to captive portal
    Posted Jul 20, 2015 10:43 PM
    I installed clearpass CPPM and guest module and I configured everything by after I try to connect SSID, it redirect to captive portal but there's alert that "the page contains too many server redirects"
    I configure redirect page as http://10.10.1.93/guest/guest_register.php
    and has firewall policy to allow captive portal
  • 2.  RE: Guest not access to captive portal
    Posted Jul 20, 2015 10:45 PM
    Please post the output of:
    show rights <captive-portal-role>
  • 3.  RE: Guest not access to captive portal
    Posted Jul 20, 2015 10:54 PM
    Derived Role = 'G-guest-logon'
    Up BW:No Limit Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    ACL Number = 83/0
    Max Sessions = 65535
    Captive Portal profile = G-cp_prof
    Application Exception List
    Name Type
    Application BW-Contract List
    Name Type BW Contract Id Direction
    access-list List
    Position Name Type Location
    1 global-sacl session
    2 apprf-G-guest-logon-sacl session
    3 captiveportal session
    4 logon-control session
    global-sacl
    Priority Source Destination Service Application Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan ClassifyMedia IPv4/6 Contract
    captiveportal
    1 user controller svc-https dst-nat 8081 Low 4
    2 user any svc-http dst-nat 8080 Low 4
    3 user any svc-https dst-nat 8081 Low 4
    4 user any svc-http-proxy1 dst-nat 8088 Low 4
    5 user any svc-http-proxy2 dst-nat 8088 Low 4
    6 user any svc-http-proxy3 dst-nat 8088 Low 4
    logon-control
    1 user any udp 68 deny Low 4
    2 any any svc-icmp permit Low 4
    3 any any svc-dns permit Low 4
    4 any any svc-dhcp permit Low 4
    5 any any svc-natt permit Low 4
    6 any 169.254.0.0 255.255.0.0 any deny Low 4
    7 any 240.0.0.0 240.0.0.0 any deny Low 4
    Expired Policies (due to time constraints) = 0
    Thank you for fast reply
  • 4.  RE: Guest not access to captive portal
    Posted Jul 20, 2015 10:57 PM
    You need to allow your ClearPass servers. Go to Configuration > Stateful Firewall > Destinations and add a destination called CLEARPASS. Add in your ClearPass IPs.
    Now go to your captive portal profile (under L3 authentication), find the Whitelist option and select the netdestination you just created and add it.
