Guest password and sponsor email fields
  • 1.  Guest password and sponsor email fields
    Posted Jun 06, 2013 11:25 AM
    Hi
    In this period I’m using clear-pass ver 6.1.0.50961.
    I’m using the "guest self-registration".
    I have two basic needs:
    1)Change the type of password that clear-pass create. Now the password contain only number if it possible I wish that it contain also letter and symbol.
    2) in the field "sponsor email" I wish that the guest can only insert email that contain a specific word. For example the name of my company.
    So the guest cannot insert an invalid email for example the own mail address.
    I see that if I customize the field I can modify the method that is used to generate a password.
    I see this
    Initial Value:
    array (  'generator' => 'GLOBALS',)
    Value to initialize this field with when the form is first displayed.
    now.. How I can modify this in order to satisfy my needs?
    For the e-mail, I have seen something like this.. But I have the same problem, how can change the behavior of clear-pass in order to check that the sponsor's mail address contain name of my company?
    Thank you
    regards
  • 2.  RE: Guest password and sponsor email fields
    Posted Jun 06, 2013 11:57 AM
     array (
       'allow' =>
       array (
         'goodemail.com',
         'alsovalid.edu',
       'deny' =>
       array (
