Guest Portal - expire_after problem
  • 1.  Guest Portal - expire_after problem
    Posted Sep 05, 2018 08:12 AM
    Hey
    I need to set the initial value of the "expire_after" field to near 6 months. For example 4800 hours. When trying this, or changing to for example 100 or 200 hours, the guest portal throws this error when hitting the "registrer" button:
    Please choose from one of the available options.
    Amount of time before this account will expire.
    It seems like CPPM doesnt read the value and sees it as empty. When setting it to 24 again it works as expected.
    Anyone know why ?
  • 2.  RE: Guest Portal - expire_after problem
    Posted Sep 05, 2018 09:06 AM
    The validator is likely restricting the value. You can remove the validator by setting it to (No Validation) and your 4800 entry will be accepted.
    *The validator is directly below the value in the expire_after field.
  • 3.  RE: Guest Portal - expire_after problem
    Posted Sep 05, 2018 11:19 AM
    The expire_after field validator checks for valid expiration value (pre-defined) under Configuration > Guest Manager > Expiration Options. These pre-defined values will be available when you use interface type drop down.
    You can go ahead define the values you need under "Guest Manager > Expiration Options" as shown below and use those values in the filed (or) go ahead and disable the validator as suggested by James in the above post.
