Guest Portal not working with Android
  • 1.  Guest Portal not working with Android
    Posted May 24, 2021 11:12 AM
    Hi All
    Bit of a strange issue
    This wireless network has been up and running for about 4 years - no issue
    2x Model: Aruba7205
         Version: 6.5.3.4
    Client is using  the Guest portal page on the controller
    From Friday anyone on an Android OS gets a blank page - instead of redirecting to the portal login page
    but works fine with anyone using iOS
    client says it is across multiple Guests and Android OS versions
    No changed on the controller from what I can see and the .pfx cert has not expired
    any ideas?
    thank you
    Barry Leicher
  • 2.  RE: Guest Portal not working with Android
    Posted May 25, 2021 04:20 AM
    Hi
    Do you have blank page on popup page or on any browser ? Did you try go to web page through example Chrome Browser ?
    Regards
    Piotr Filip
    ACEX#41/ACCX/ACDX/ACMX/CWNA/CWSP
