Guest Provisioning Default Role
  • 1.  Guest Provisioning Default Role
    Posted Feb 13, 2015 11:59 AM
    We give front desk users guest provisioning access which puts users into the default "guest" role, is there a way to default what role they go into? We are trying to steer guest accounts into a role that is different then the default (i.e. SSIDName-Role vs guest)
    I know this is possible from within the controller guest provisioning but we don't want to give users that much access.
  • 2.  RE: Guest Provisioning Default Role
    Posted Feb 13, 2015 12:32 PM
    Edited to reflect post-auth role instead of initial role in #2
    The role assignment for guests within the controller can be done in a couple different ways:
    1) Create a guest account and assign a role.   By default the captive portal profiles use "default" server group for authentication.  This server group has a server derived rule that assigns the user-role to be the value or role within the internal DB.
    2) Set a default guest role for the captive portal profile for your guests (SSIDName-Role in your case).   Make a new server group (copy of default), but remove this server derived rule.  Assign this server group to the Captive Portal profile.
    • In option 1, the server derived rule will override the initial role for the AAA profile, thus they are assigned "guest".
    • In option 2, there is no server derived rule, so the default role of the Captive Portal profile is assigned, thus they are assigned "SSIDName-Role"
  • 3.  RE: Guest Provisioning Default Role
    Posted Feb 13, 2015 01:45 PM
    Option 1 is already doable
    Option 2 is I guess what we are trying to do but already have an initial role on the AAA profile set. Not sure about the server derived rule since the default doesnt have any set from what I can tell.
    This is basically our config with names changed up a bit but basically we want initial role "SSID-Guest-Logon-Role" and authenticated role "SSID-Guest-Role". Anything the guest-manager puts in they are currently being put int to "guest" role by default.
    wlan virtual-ap "VAP-SSID-Guest"
    aaa-profile "AAA-SSID-Guest"
    ssid-profile "SSID-Guest"
    vlan xxx
    band-steering
    broadcast-filter all
    aaa profile "AAA-SSID-Guest"
    initial-role “SSID-Guest-Logon-Role"
    aaa authentication captive-portal "CP-SSID-Guest"
    default-role “SSID-Guest-Role"
    server-group "internal"
    redirect-pause 2
    protocol-http
    welcome-page "http://www.pickles.com"
    apple-cna-bypass
    aaa server-group "default"
    auth-server Internal
  • 4.  RE: Guest Provisioning Default Role
    Posted Feb 14, 2015 08:40 AM
    Your config looks good so long as the CP-SSID-Guest captive portal profile is assigned to the SSID-Guest-Logon-Role role.  However, the above output shows that the default server group does indeed have the server rule set.  It is a default setting, so it does not show up in the CLI.  If you had removed it, you'd see:
    no set role condition role value-of
    To confirm this, run one of the following commands.
    When the user is logged in:
    • show user ip <ip-of-user>
    • Looks for the User Role deriviation field to confirm how the user was assigned the role
    show aaa server-group default
    • Verify Role/VLAN deriviation rule is set.
    (aruba-7010) #show aaa server-group default
    Fail Through:No
    Load Balance:No
    Auth Servers
    Name      Server-Type  trim-FQDN  Match-Type  Match-Op  Match-Str
    Internal  Internal     No
    Role/VLAN derivation rules
    Priority  Attribute  Operation  Operand  Type    Action    Value  Validated
    1         role       value-of            String  set role         No
  • 5.  RE: Guest Provisioning Default Role
    Posted Dec 15, 2022 11:32 AM
    Hi @clembo
    I've encountered the very same problem @flava described.
    I've tried to apply your recommendations but it's not working for me, not sure if I'm missing something or it's indeed not possible to change the role. My goal is to assign guest clients role auth-guest.
    My setup is basically identical:
    wlan virtual-ap "JMHotspot"
    aaa-profile "JMHotspot"
    vlan 35
    ssid-profile "JMHotspot_ssid_prof"
    blacklist-time 28800
    aaa profile "JMHotspot"
    initial-role "guest-logon"
    user-role guest-logon
    captive-portal "JMHotspot"
    access-list session ra-guard
    access-list session captiveportal
    access-list session guest-logon-access
    access-list session v6-logon-control
    access-list session captiveportal6
    access-list session block-internal-access
    aaa authentication captive-portal "JMHotspot"
    default-role "auth-guest"
    server-group "WLC_internal"
    redirect-pause 3
    single-session
    aaa server-group "WLC_internal"
    auth-server Internal position 1
    ! in default server group I removed "set role condition Role value-of"
    However, guest clients created by Guest Provisioning Portal never get role auth-guest, instead they always end up with default guest role.
    (WLC-JMS-PRI) [mm] #show local-userdb
    User Summary
    Name Password Role E-Mail Enabled Expiry Status Sponsor-Name Remote-IP Grantor-Name
    guest-6218037 ******** guest Yes 12/15/2022 18:11 Active 0.0.0.0 admin
    guest-9797812 ******** guest Yes 12/15/2022 18:32 Active 0.0.0.0 admin
    (WLC-JMS-PRI) [mm] #show aaa authentication captive-portal JMHotspot
    Captive Portal Authentication Profile "JMHotspot"
    Parameter Value
    Default Role auth-guest
    Default Guest Role guest
    Server Group WLC_internal
    Redirect Pause 3 sec
    User Login Enabled
    Guest Login Disabled
    Logout popup window Enabled
    Use HTTP for authentication Disabled
    Logon wait minimum wait 5 sec
    Logon wait maximum wait 10 sec
    logon wait CPU utilization threshold 60 %
    Max Authentication failures 0
    Show FQDN Disabled
    Authentication Protocol PAP
    Login page /auth/index.html
    Welcome page /auth/welcome.html
    Show Welcome Page Yes
    Add switch IP address in the redirection URL Disabled
    Please do you have any idea what to change so that guest users get configure role?
    Thank you!
