Guest Provisioning for IAPs
  • 1.  Guest Provisioning for IAPs
    Posted Jul 10, 2012 12:45 PM
    Is there a roadmap for this feature on IAPs?
  • 2.  RE: Guest Provisioning for IAPs
    Posted Jul 10, 2012 01:02 PM
    You should talk to your local sales team about that.
  • 3.  RE: Guest Provisioning for IAPs
    Posted Jul 10, 2012 08:13 PM
    Thanks for the reply, but the local sales team does not have the answer to this.   I was hoping to possibly get some feedback from other Aruba employees outside of my area that may have some insight into any future roadmap on the topic.   As a partner I see this request come in from customers repeatedly.   One response would be to sell Clearpass Guest/Amigopod, but most customers that are considering Instant are budget conscious, so a centralized provisioning portal is unavailable to them on the Instant platform.
  • 4.  RE: Guest Provisioning for IAPs
    Posted Oct 22, 2012 05:34 AM
    what exactly are you looking for? because it seems IAPs can do guest access and creating guest users, is it self provisioning?
  • 5.  RE: Guest Provisioning for IAPs
    Posted Oct 30, 2012 08:50 PM
    Set up a guest ssid (and network vlan) and create local accounts. Make sure your PEF is configured appropriately.
    I'm told that the IAP supports local captive portal but not external; however, this might change in upcoming versions of code.
  • 6.  RE: Guest Provisioning for IAPs
    Posted Oct 30, 2012 11:11 PM
      IAP currently supports internal and external Captive Portal.
  • 7.  RE: Guest Provisioning for IAPs
    Posted Nov 06, 2012 05:13 PM
    Here is the video showing you how to configure Aruba Instant Captive Portal using Internal authentication server. The demo is based on Aruba Instant OS 6.1.3.4_3.1.0.0.
    (view in My Videos)
