Guest Provisioning in AOS8 environment
  • 1.  Guest Provisioning in AOS8 environment
    Posted Jun 27, 2018 11:27 AM
    Hi guys!
    I would like to configure Guest Provisioning in MM-MD AOS8 environment.
    AOS 8.3.0.0 config guide states this:
    Configuring Guest Fields
    1. In the Managed Network node hierarchy, navigate to the Configuration > Services > Guest Provisioning page.
    The problem is that, there isn't Guest Provisioning page:
    I found Guest Provisioning page under MM group, but if I configure guest portal under MM, that is applied for all MD group, that's not OK.
    Furthermore if I configure it under MM, I need to add a guestprovisioner user under MM, and provisioner need to access MMs over the network, I wouldn't want to do it.
    From config guide:
    Configuring Guest Provisioning User
    Username and Password Authentication Method
    1. In the Managed Network node hierarchy, navigate to the Configuration > System > Admin page.
    The system is running AOS 8.3.0.0 (MMs and MDs also)
    Thanks!
  • 2.  RE: Guest Provisioning in AOS8 environment
    Posted Jun 27, 2018 01:28 PM
    You need to configure this under the MD/Manage Network
  • 3.  RE: Guest Provisioning in AOS8 environment
    Posted Jun 27, 2018 05:47 PM
    If I navigate there what you pointed on the picture, it's simply open guest portal page, what I customized under MM > Configuration > Guest Provisioning (customized banner, customized labels, and more..) There isn't configuration options.
    (https://<MMs-vrrp-ip>:4343/screens/switch/gpp.html)
    But the config guide states I need to configure guest portal under MDs, but there is no Guest Provisioning page.
    If I added an internal user in MDs with role guest-provisioning, opening MDs-vrrp-ip in browser, login with that account, I see a default guest-portal, not that I configured under MMs.
    This seems to me to be MM, and MDs also run 1-1 independent guest portals.
    Based on the config guide I would have to configure it under MDs, but there is no such menu item.
    (Sorry for my bad english)
