Guest Provisioning issue
  • 1.  Guest Provisioning issue
    Posted Nov 23, 2011 09:32 AM
    Hi there,
    We have an issue with guest provisioning on OS 6.1.0.0 where we cannot edit existing accounts to extend access etc.
    When I try to change the Account "End" field (where the account expiry date/time is set) and then click "Save" the session just hangs or nothing happens.
    I have tried this across multiple browsers including IE7-9 and Chrome but same result. Are there any Javascript setting necessary for this to work?
    The workaround is to setup the account from scratch which works fine.
  • 2.  RE: Guest Provisioning issue
    Posted Nov 23, 2011 09:48 AM
    Do you have this problem when logged in as an Admin or when you are logged in as  a guest provisioning user?
  • 3.  RE: Guest Provisioning issue
    Posted Nov 23, 2011 10:37 AM
    Hi Colin,
    When logged on as a Guest Provisioning user. When I log in as an admin I get full console rather than GPP so don't know if this happens with this login
  • 4.  RE: Guest Provisioning issue
    Posted Nov 23, 2011 01:03 PM
    I am using ArubaOS 6.1.0.0 anf firefox 8.0 and it works for me. Try opening a private browsing session and then try the same. It worked fine even with the java plugins disabled.
    Sathya
