Guest re-authentication
  • 1.  Guest re-authentication
    MVP
    Posted Sep 22, 2014 03:45 PM
    We have an Aruba 3600 and we are using the internal captive portal for guests, which only shows the acceptible use policy with an accept button.
    When a user accepts the device is authenticated and we have no problem, but when the device is put in your pocket for 5 minutes and you connect to guest, it prompts for the acceptible use page again with the button.
    is there a way we can extend the length of time before they are forced to re-register? We want them to stay authenticated for a longer time, but don't have ClearPass or any other MDM solution.
    #3600
  • 2.  RE: Guest re-authentication
    Posted Sep 22, 2014 03:48 PM
    You can try changing the user idle timeout in the captive portal configuration. (AOS 6.3+)
  • 3.  RE: Guest re-authentication
    MVP
    Posted Sep 22, 2014 03:55 PM
    Right now it's not set, is there a default it uses?
  • 4.  RE: Guest re-authentication
    Posted Sep 22, 2014 04:12 PM
    It will use the global reauthentication interval if nothing is specified.
