Guest Registration Disable Issue
  • 1.  Guest Registration Disable Issue
    Posted May 07, 2018 07:13 PM
    I have been able to get a self registration working for IOT devices where there is not a captive portal using a COA to another VLAN (666).  However, when I disable that registred device, it kicks it off of the VLAN666 but the device still has an IP Address showing and it can still browse the internet.  However, when I forget the network and then try and reconnect, I see the expected behavior again.
    It seems that I am missing a role communication with the controller.  Thoughts?  Attached are my clearpass enforcements.
  • 2.  RE: Guest Registration Disable Issue
    Posted May 07, 2018 07:27 PM
    Just to be clear, you're using Device Registration, not Guest Self-Registration, correct?
  • 3.  RE: Guest Registration Disable Issue
    Posted May 07, 2018 07:29 PM
    Correct. Device Registration.
  • 4.  RE: Guest Registration Disable Issue
    Posted May 07, 2018 07:36 PM
    Do you see a DM/CoA tab in the original access tracker request?
  • 5.  RE: Guest Registration Disable Issue
    Posted May 07, 2018 07:42 PM
    There is:
    Date and Time:  May 07, 2018 15:50:45 PDT
    Application Name:  Policy Manager
    RADIUS CoA Action Type:  Disconnect
    RADIUS CoA Action Name:  [ArubaOS Wireless - Terminate Session]
    Status Code:  1
    Status Message:  Radius [ArubaOS Wireless - Terminate Session] successful for client 0034da9dc724.
    RADIUS CoA Attributes:  Calling-Station-Id = 0034DA9DC724
  • 6.  RE: Guest Registration Disable Issue
    Posted May 07, 2018 08:02 PM
    Also, When I reactivate that device, it doesn't seem to re-check for the network.  There are a few things about this that are getting me.  The device shows up in the association table, but if I do a lookup in the user-table, they aren't showing up and they show offline in the CPPM access tracker.
  • 7.  RE: Guest Registration Disable Issue
    Posted May 07, 2018 08:49 PM
    Best to work with Aruba TAC.
