last person joined: 10 hours ago
Guest Registration Page
  • 1.  Guest Registration Page
    Posted Jun 06, 2013 09:01 AM
    I would like to know how to change the default authentication page, i'm able to chanfe header, footer, title, fields etc but i don't know where to go to change default color and logo....
    Anyone can help me ?
    Thank's.
    Pascal,
    If's it's possible to add overlib.js to add comments, it's also be pratical for me ....
  • 2.  RE: Guest Registration Page
    Posted Jun 06, 2013 09:21 AM
    There are two ways to do this:
    You could edit the Weblogin and put a checkmark next to "Custom Form", OR:
    You could create a custom "Skin" so that you will change this on all your forms.
    Attached is a PDF on how to do this....
    Attachment(s)
  • 3.  RE: Guest Registration Page
    Posted Jun 06, 2013 10:00 AM
    Thank's M.Joseph for your quick answer,
    if i want to use this custom skin, i suppose this plugin have to be enable in our configuration ?
  • 4.  RE: Guest Registration Page
  • 5.  RE: Guest Registration Page
    Posted Jun 06, 2013 10:08 AM
    Thank's for your help.
    It's very appreciate.
  • 6.  RE: Guest Registration Page
    Posted Jun 06, 2013 11:01 AM
    If you mean enable in the admin->plugin page that changes the global look of guest (the administrion pages).
     You can reference the skin in the guest web portal/self provisioning without it being "enabled" and it will be specific to those web logins.
  • 7.  RE: Guest Registration Page
    Posted Jun 06, 2013 03:10 PM
    Thank's Evan, i will do that.
