Guest Registration with Extreme Wireless Controller
  • 1.  Guest Registration with Extreme Wireless Controller
    MVP
    Posted Nov 30, 2016 11:49 AM
    Hi all,
    So I have the captive portal redirect working, registration is good, but when we click Login after, it is failing. Extreme is not a preset option for the Login part, what settings would I need to have? Does someone have this working they could provide info/screenshots?
    Thanks.
  • 2.  RE: Guest Registration with Extreme Wireless Controller
    MVP
    Posted Nov 30, 2016 03:35 PM
    UPDATE -
    Worked with ClearPass TAC engineer, was unable to identify the correct settings. Recommended reaching out to Extreme TAC to try and collect the info. If anyone has a working example, it would be really helpful.
    Thanks.
  • 3.  RE: Guest Registration with Extreme Wireless Controller
    Posted Jul 17, 2017 11:10 AM
    Hi Michael
    Did you ever get this working?
    Andrew
  • 4.  RE: Guest Registration with Extreme Wireless Controller
    MVP
    Posted Jul 17, 2017 11:14 AM
    Unfortunately I don't think we did. We were close, but there just seemed to be something odd happening with the authentication being submitted back to the controller. If we set it to controller initiated, it wouldn't work, if we set it to server-initiated, it would sort of work. Never fully worked though.
    Michael Haring
    Senior Network Engineer
    Comm Solutions Company
    Direct: (610) 246-6037
    Office: (610) 889-1280 x176
    Email: mharing@commsolutions.com
    Sent from Outlook Web App
