last person joined: 11 hours ago
Guest Self Registration Erorr,
  • 1.  Guest Self Registration Erorr,
    Posted Jun 30, 2016 09:45 AM
    Hi All,
    I need your advice, I already install Clearpass and configure Guest Self-Registration feature.
    When i useing Virtual Contoller and integrate with Clearpass the Guest Self-Registration Feature running-well. But when i using controller I Got the erorr message like below
    http://10.8.100.6/guest/guest_register.php?errmsg=Authentication%20failed&_browser=1
    But the guest user already on Clearpass.
    Fyi I already installed the controller and Clearpass with Guest feature with the same configuration, on site A the feature running normally but on site B i got the message like that.
    kindly need your advise
    Thank you in advance
  • 2.  RE: Guest Self Registration Erorr,
    Posted Jun 30, 2016 09:49 AM
    That means that the authentication was rejected for whatever reason.
    Did you see the post here?  http://community.arubanetworks.com/t5/Aruba-Solution-Exchange/IAP-ClearPass-Guest-Captive-Portal/ta-p/202675
  • 3.  RE: Guest Self Registration Erorr,
    Posted Jun 30, 2016 10:11 AM
    Even though in Clearpass Display that the User is Active ?
    I configure using Controller 7010 with image 6.4.3.4
    Kindly need your advise,
  • 4.  RE: Guest Self Registration Erorr,
    Posted Jun 30, 2016 10:22 AM
    What does the access tracker say?
  • 5.  RE: Guest Self Registration Erorr,
    Posted Jun 30, 2016 11:52 PM
    Please Find Below
    Kindly need your advice,
    Thank you
    Sandi Pradana
