last person joined: 4 hours ago
Guest Sponsorship Validity Check Question
  • 1.  Guest Sponsorship Validity Check Question
    Posted Nov 16, 2016 09:43 AM
    Hi all,
    I have recently implemented a sponsor based guest sponsorship system. The only disadvantage is that I have been asked to use the non-authenticated sponsor email confirmation instead of making the sponsors log in.
    I have restricted the sponsor emails so that they must be from our domain, however, students have the same domain. I would like to be able to restrict them from being able to sponsor themselves.
    All student email addresses are in the format of 'aabbbbbb55@domain.com' (first 2 initials, up to 6 of last name, and two digits)
    Is there a way to restrict this format via the validity checker?
    --Ben
  • 2.  RE: Guest Sponsorship Validity Check Question
    Posted Nov 16, 2016 10:33 AM
    Just change the doman from gmail.com to your domain:
    ^[A-Za-z]+[0-9]{2}@gmail.com
    Insert it as below in the sponsor email field (assuming you're using that one) and set the validator to IsRegexMatch.
    Edit: removed the 0-9 from the first part of the regex.
  • 3.  RE: Guest Sponsorship Validity Check Question
    Posted Nov 16, 2016 12:21 PM
    Changing the validator to regex would drop my current domain restrictions correct?
    If so, can I add multiple regex statements?
  • 4.  RE: Guest Sponsorship Validity Check Question
    Posted Nov 16, 2016 01:09 PM
    A single regex would work.
    E.g. the following regex will match any number of a-z characters @ gmail.com anbd ggg.com.
    ^[A-Za-z]*@(([g][m][a][i][l])|([g][g][g])).com
    I would recommend checking out the following regex site to learn how to use regex expressions. https://regex101.com/
