last person joined: 7 hours ago
Guest SSID network and need to know the format for the Aruba guest landing page?
  • 1.  Guest SSID network and need to know the format for the Aruba guest landing page?
    Posted Feb 04, 2014 02:52 PM
    Hi, we are working on our Guest SSID and had a few question:
    1.  need to know the format for the Aruba guest landing page?
    2. is it possible to create a script of some sorts in the CLI to restrict Guest SSID wireless access from 9am-5pm?
  • 2.  RE: Guest SSID network and need to know the format for the Aruba guest landing page?
    Posted Feb 04, 2014 02:56 PM
    Do you have ClearPass Guest ? or you are using Controller Captive portal ?
  • 3.  RE: Guest SSID network and need to know the format for the Aruba guest landing page?
    Posted Feb 04, 2014 03:09 PM
    1) If you are using the built in controller captive portal, you can use the built in template or upload a custom HTML page.
    Below is a guide that will show you how to create it:
    http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Captive_Portal/Internal_Captive_Portal.htm
    2) You can restrict access without using a script by using the "Deny time range" feature in the virtual-ap profile for the SSID.
