last person joined: 11 hours ago
Guest SSID with PSK and Role based bandwidth contract
  • 1.  Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 02:58 PM
    Hi I am trying to setup my Guest SSID with a splash screen, with this I would like to trottle back the bandwidth of the users to 2 mbps up and downstream.
    when I set the PSK on the security tab and then set the 2mbps on the access tab and add a rule under bandwidth contract.  All the settings wont save the role based/bandwith rule gowes back to unrestricted.
    Am I missing something
    Thanks for the replies
  • 2.  RE: Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 04:13 PM
    EDIT:  Instant AP
  • 3.  RE: Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 04:23 PM
    1. So I goto Configuration> Access Control there is no user roles just unrestricted, Network based and role based. I went into role based and set the bandwidth but it wont keep the setting if I have encryption enabled, when I go back to Access it is back at unrestricted
  • 4.  RE: Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 04:40 PM
  • 5.  RE: Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 04:52 PM
    • OK we dont have an enforcement license installed
    If I got to WLAN setting and advanced options there is an area for bandwidth Limits do I need the enforcement License for that and will that give me what I need
  • 6.  RE: Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 04:58 PM
  • 7.  RE: Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 04:43 PM
    We created a new user role called guest and then under the Bandwidth Contracts tab we set bandwidth limits.  Hope this helps
  • 8.  RE: Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 05:33 PM
    I just tested it on IAP running 6.5.4.4. Yes the knob goes back to unrestricted, however if you move it back to Role based, & click on the role, you would see the bandwidth contract in place.
    If you SSH into IAP and do a show run, you can see something like:
    wlan access-rule "SSID1"
    index 3
    rule any any match any any any permit
    bandwidth-limit downstream 4
    bandwidth-limit upstream 2
    So definitely the config is getting saved, atleast on the latest version.
    But why did the slider move back to unrestricted?
    I will get a bug filed for it.
  • 9.  RE: Guest SSID with PSK and Role based bandwidth contract
    Posted Feb 01, 2018 05:39 PM
    Yes it is there, thank you
    •  rule any any match any any any permit
       bandwidth-limit peruser downstream 2048
       bandwidth-limit peruser upstream 2048
