Guest / Tips device database
  • 1.  Guest / Tips device database
    MVP
    Posted Jan 08, 2014 01:26 PM
    Pretty confused as to why the /tips endpoint repository and the /guest device database are separate.
    I have a request from a customer to have an operator profile that allows removal of devices. We're currently allowing a limit on the number of devices a user may bring on the network. Unfortunatally its the /tips endpoint repository that's used to get this working.
    And I don't know of a way to allow operators access to just that bit.
    Something like this would be easy if we could use the /guest device database  for this.
    Is there a way to achieve what is requested here? Or am I missing something obvious here?
  • 2.  RE: Guest / Tips device database
    Posted Jan 08, 2014 02:11 PM
    Please download the CPPM 6.2 policy manager User Guide and search for "custom admin privileges"
  • 3.  RE: Guest / Tips device database
    Posted Jan 08, 2014 03:00 PM
    Here is the custom role we use for our Help Desk.
    This allows access to the following:
    MONITORING
      Live Monitoring:
         - Access Tracker
         - Analysis & Trending
         - Endpoint Profiler
    CONFIGURATION
      Identity:
         - Endpoints
         - Guest Users
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <TipsContents xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
      <TipsHeader exportTime="Wed Jan 08 14:55:46 EST 2014" version="6.2"/>
      <AdminPrivileges>
        <AdminPrivilege allowPasswords="true" accessType="FULL" name="Brandeis-HelpDesk" description="Role for Brandeis help desk">
          <AdminTask taskid="mon.li.ep">
            <AdminTaskAction type="RWD"/>
          </AdminTask>
          <AdminTask taskid="con.id.ep">
          </AdminTask>
    	  <AdminTask taskid="con.id.gu">
          </AdminTask>
          <AdminTask taskid="mon.li.ad">
          </AdminTask>
          <AdminTask taskid="mon.li.sp">
          </AdminTask>
        </AdminPrivilege>
      </AdminPrivileges>
    </TipsContents>
  • 4.  RE: Guest / Tips device database
    MVP
    Posted Jan 08, 2014 03:23 PM
    Guess I did miss the obvious on this one. :smileyembarrassed:
    thanks for the pointer but  I guess I'll have to check it out tomorrow Colin.
    Currently ClearPass Policy Manager 6.2 User Guide from support site link goes here: https://d1x3hnhct7p62q.cloudfront.net/SupportSite/ProductionFiles/6265d2a4-9565-4e7d-8b3c-f7d6487e6e1f/Aruba_CPPM_User_Guide.pdf?Expires=1389212317&Signature=I7OGedJxllWUuUi7iZgFc0GSQEG1KuvZA5S~QcPoJodnp~n8ce0Ka6tPugsXhkJy~86IFZFCn3NsGCJI4ktaGuVg0b3IWjqw2TCgV-nO~oWCklqNkhGpeqTOBOKePCvlISmBY5-Gc~t8eDfaxsqTcR2ccJ1v4tUz5OhoDUo99oQq6cl0zwrwcIUw287DfIUEpFxWnjvAQ9PtFWWkWd6ZZrhoR0G4lnsDhsQ913pd0zwjBrntlCuNSRi0dEu5TBPuSq2H1~~AAs8VNV7c738C7tMW~qFTTTWFcYt8UBNZ800rtGyp~KX57qzTsVe1fUziFf0ZfrkECiqKO6zeEAPQvg__&Key-Pair-Id=APKAIA2CDKVYCRBEJEMA
    and gives me:
    This XML file does not appear to have any style information associated with it. The document tree is shown below.
    <Error>
    <Code>AccessDenied</Code>
    <Message>Access denied</Message>
    </Error>
    Tim, thanks a bunch for the example!
  • 5.  RE: Guest / Tips device database
  • 6.  RE: Guest / Tips device database
    MVP
    Posted Jan 08, 2014 03:29 PM
    Same redirect to cloudfront and an access denied xml error.
    No worries, I'll check it out tomorrow at work.
  • 7.  RE: Guest / Tips device database
    MVP
    Posted Jan 09, 2014 03:57 AM
    For those running into the same download issues:  these were caused by my HTTPS Everywhere plugin.
    It forced the cloudfront.net link that housed the actual files to use https and apparently it didn't like that.
