Guest URL-REDIRECT on Cisco L2 Switch
  • 1.  Guest URL-REDIRECT on Cisco L2 Switch
    Posted Aug 02, 2016 03:46 AM
    Hi
    I have a setup of Guest Users connected to Cisco L2 switch (2960), I want to redirect their internet browsing access to the Guest Captive-Portal page, then got internet access after authentication.
    The CP service configured "as attached", and the guest captive-portal configured.
    The users assigned to guest VLAN but they are not redirected to the captive-portal page
    - The used switch is 2960
    - The used switch version is (C2960-LANBASEK9-M), Version 12.2(55)SE7
    - The switch is L2 switch.
    - The users VLAN GW is in another L3 switch
    SO::
    - Is the switch must be L3 switch?
    - Is the users VLAN GW must be on the target switch (for the URL-Redirect to be accepted)
    - Is there a special configuration required on the switch rather than the below?;
    aaa new-model
    aaa authentication dot1x default group radius
    aaa authorization network default group radius
    aaa accounting dot1x default start-stop group radius
    aaa server radius dynamic-author
    client 10.0.0.179 server-key aruba123
    port 3799
    auth-type all
    dot1x system-auth-control
    interface FastEthernet0/2
    switchport access vlan 10
    switchport mode access
    authentication order dot1x mab
    authentication priority dot1x mab
    authentication port-control auto
    authentication periodic
    authentication timer reauthenticate server
    mab
    dot1x pae authenticator
    dot1x timeout server-timeout 30
    dot1x timeout tx-period 10
    dot1x max-req 3
    dot1x max-reauth-req 3
    spanning-tree portfast
    ip http server
    ip http secure-server
    radius-server host 10.0.0.179 auth-port 1645 acct-port 1646 key aruba123
    radius-server vsa send authentication
  • 2.  RE: Guest URL-REDIRECT on Cisco L2 Switch
    Posted Aug 08, 2016 04:48 AM
    I think, in short, the answer to both of the above questions is "yes" for this to work.
  • 3.  RE: Guest URL-REDIRECT on Cisco L2 Switch
    Posted Aug 09, 2016 03:10 AM
    Hello
    Do you have any documnet/article about this issue?
    If so, then this URL-Redirect feature is not reliable, because most of the users are connected to L2 switches and their GW resides in one switch (the Core L3 switch)...
    Is it?
  • 4.  RE: Guest URL-REDIRECT on Cisco L2 Switch
    Posted Aug 09, 2016 04:26 AM
    Can you not set the url-redirect up on the L3 switch?
  • 5.  RE: Guest URL-REDIRECT on Cisco L2 Switch
    Posted Aug 25, 2016 01:19 PM
    Have you had any success with url-redirect?
    I've found the following Cisco document that lists the supported platforms for the url-redirect command.
    http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ibns/configuration/15-e/ibns-15-e-book/ibns-webauth-origin-url.pdf
    Attachment(s)
    pdf
    ibns-webauth-origin-url.pdf   1.34 MB 1 version
