guest user
  • 1.  guest user
    Posted Dec 15, 2014 09:47 AM
     according to the topolgy
    how redirect a guest user to proxy (internet) when using a captive portal
    sorry for the inconvenience
  • 2.  RE: guest user
  • 3.  RE: guest user
    Posted Dec 16, 2014 05:16 AM
    thank's for reply
    i add some information on the topology so our proxy is on forward mode and ther's two GW one on the controller and the seconde on the wired LAN for the employs
  • 4.  RE: guest user
    Posted Dec 16, 2014 05:17 AM
    need help
  • 5.  RE: guest user
    Posted Dec 20, 2014 01:41 PM
    did you read victorfabian's info? the general idea is to dst nat the traffic, did you try that?
  • 6.  RE: guest user
    Posted Dec 21, 2014 10:10 AM
    hi boneyard
    yes i did it!  but the traffic is not redirected to the proxy ????
    and the user are not redirected to the captiveportal
  • 7.  RE: guest user
    Posted Dec 21, 2014 11:00 PM
    Try to bypass Captive Portal to see if your guest proxy redirect works.  This can be done simply by changing the initial role in guest aaa profile to “guest”.
    After you have a working proxy redirect then you can work on your guest Captive Portal.
    Captive Portal requires DNS, so if you are using external DNS, your CP will not redirect until your guest proxy works first.
  • 8.  RE: guest user
    Posted Jan 07, 2015 11:06 AM
    no way
    if desabling  captive portal redirection work's and when stoping redirection captive portal work's again ??????? thank's for your help
    when the controller is natted to outside all work's fine but
    QUID can we filter a trafic with the controller ex Facebook......
    thank's
  • 9.  RE: guest user
    Posted Jan 08, 2015 01:30 PM
    sorry i don't understand what you are asking.
