hi all ,
how can i log guest users access in an external Syslog Server.
regards.
i'm using a another external Syslog Server
i'm using the captive portal with the local database
i don't know it by hard. you can try just turning on some services at debug level and see where it turns up.
there is an easy option like: log system guest access or such.
