I have searched the Airheads without finding a specific answer to my question.
I have guest users authenticated thru a Captive Portal and the user is in the local db.
The controller is running 6.1.2.6 and is a 3200XM.
When the user leaves the building heading for another building, but with AP's on the same controller, they loose connectivity to the AP and will have to re-authenticate. I have checked that the re-auth. timer on the "guest" role is at 0, so you should need to re-auth.. As i understand this timer is only for users that have an association to the wireless network.
I have not been able to find any info on how long guest users are cached in the authenticated state. I understand that this should not be very long as they are guest users, but at least 5 mins is acceptable.
Am i missing something or is there a way to make the controller wait a little longer before classifying the guest user as "not authenticated" after a short while.
Roar Fossen
#3200
