Guest Wifi with PSK password and with external captive portal authentication
  • 1.  Guest Wifi with PSK password and with external captive portal authentication
    Posted Apr 26, 2015 01:04 AM
    I'm setting up a guest wifi, and would like to achieve the following:
    (1) When guest logs on to SSID, he is prompted for a password (first level authentication)
    (2) After the guest passes first level authentication, would then like to redirect the guest to an external captive portal for a second level of authentication. Purpose for this is to capture more details about the guest (e.g. social media platform)
    Could you please how this may be achieved? Got a little confused reading the user guide - couldn't get a definitive answer as to whether this is possible or not. Thanks.
  • 2.  RE: Guest Wifi with PSK password and with external captive portal authentication
    Posted Apr 26, 2015 01:34 AM
    To add on to the context of the question. These are being used:
    - IAPs (135, 215)
    - Aruba Central to configure and manage the devices
    Reason for requiring the first level of authentication is so that the guest wifi is only to be used by guests that are provided with this password.
  • 3.  RE: Guest Wifi with PSK password and with external captive portal authentication
    Posted Apr 26, 2015 04:41 AM
    You would need ClearPass or some third party captive portal product to do what you want to accomplish.
  • 4.  RE: Guest Wifi with PSK password and with external captive portal authentication
    Posted Apr 26, 2015 07:19 AM
    We are going to do the same thing and write our own portal in the next few months. This page should help get things started, https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-154
  • 5.  RE: Guest Wifi with PSK password and with external captive portal authentication
    Posted Apr 26, 2015 10:17 AM
    Thanks for your reply. However, what I'm looking to do is to perform the first level of authentication at the AP (using WPA/WPA-2) before passing it to the external captive portal, which I am already using.
    Would like to know how this can be configured/setup in the Aruba Central.
    Thanks.
  • 6.  RE: Guest Wifi with PSK password and with external captive portal authentication
    Posted Apr 27, 2015 04:35 AM
    1. Set the splash page to be external
    2. Create a captive portal profile which points to your external captive portal (ClearPass etc)
    3. Configure encryption (Pre-Shared Key)
    4. Set up your authentication server (ClearPass etc)
    Like the other guys were saying you'll need an external captive portal such as ClearPass to get this working.
    Cheers
    James
  • 7.  RE: Guest Wifi with PSK password and with external captive portal authentication
    Posted Apr 27, 2015 04:54 AM
    This might be worth a watch if you haven't seen it yet.
    Module - 9 Aruba Central and IAP - Captive Portal
    https://www.youtube.com/watch?v=ArS7h6cPu6A
