Guest wireless Network Questions need help ASAP plz.
  • 1.  Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 04:44 PM
    I have multiple Aruba controllers that i need to check if they have Guest wireless Networks I tried checking  SSID's but some do not show if it is public.. is there an easy way to get this information??
    Thanks in Advanced.
  • 2.  RE: Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 05:06 PM
    Assuming your guest WLAN is open and your internal network has security, you can look at the SSID profiles to tell which is an open network and which isn't.
    Configuration > Advanced Services > All Profiles
    Expand Wireless LAN then click on SSID Profiles.  Click on each profile to see what the 802.11 security is.
    That is the best way that I can think of...
  • 3.  RE: Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 05:08 PM
    I tried doing it this way..I can log to all master controller if i need to.. Is there any way you know how to do it through SSH?? and if so what would we look for?? im assuming the command would be running-configuration?  Thanks for the quick response on this..
  • 4.  RE: Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 05:10 PM
    see the response after mine, much easier via CLI "show ap essid"
  • 5.  RE: Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 05:13 PM
    im typing in show ap essid from the master but its comming back with num ESSID (0) but there should be alot of SSID's on this controller.
  • 6.  RE: Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 05:14 PM
    If the master does not have any APs broadcasting wireless, it will not return anything.  Try it on the local controller, instead.
  • 7.  RE: Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 05:18 PM
    Thats Exactly what i was doing wrong! thanks so much you saved me alot of time!! appreciate your fast response on this!!!
  • 8.  RE: Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 05:26 PM
    one more thing .... im going through and some of these are showing open but knowing SSID are not showing up im guessing this command doesn't show hidding SSID's? and this is showing all SSID's not just Wireless networks used by Guests is there anything else you can think of trying???
  • 9.  RE: Guest wireless Network Questions need help ASAP plz.
    Posted Nov 23, 2011 07:25 PM
    It only shows SSIDs broadcast by APs on that controller.  It will show hidden SSIDs, as well.
  • 10.  RE: Guest wireless Network Questions need help ASAP plz.
    If you type "show ap essid" on the commandline, it will show what wireless networks are open and which ones are encrypted.
