Guest Wireless only Accept Use Policy using Clearpass?
  • 1.  Guest Wireless only Accept Use Policy using Clearpass?
    Posted Jun 09, 2014 10:34 AM
    I'd like to keep forwarding our guests through clearpass so that I can continue having an option for users to login using credentials through RADIUS, but I'd like it so that Guests can just click accept and get x amount of time of access before having to accept the Use Policy again. Is there a way to make this happen?
    I came across this link, but it's controller specific and doesn't involve adding a section for Guests to click a link to log in with their RADIUS account.
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-154
  • 2.  RE: Guest Wireless only Accept Use Policy using Clearpass?
    Posted Jun 10, 2014 02:28 AM
    Yes,
    You can create a page that has a choice of who the users are and they would click the link or put a login page with a link to the guests click to accept.
    Just be forward you are going to have to walk through quite a few steps to setup a the accept terms so if your not familiar with setting one up your best bet is to work with a partner or professional service.
  • 3.  RE: Guest Wireless only Accept Use Policy using Clearpass?
    Posted Jun 10, 2014 11:17 AM
    Really I suppose the question is, is there a guide around for setting up a page that just makes a guest user accept the use policy? I can add a link to a webpage, so that really isn't the hard part.
    I just know that clearpass is generally reliant on users logging in, but I don't want guests to have a username/password.
  • 4.  RE: Guest Wireless only Accept Use Policy using Clearpass?
    Posted Jun 13, 2014 04:36 PM
    Does Clearpass have the capability of just having a user accept the TOS?
    I can't seem to figure a way for it to not check agains a user database.
    I guess the other question would be how can I get the mac to populate the user database by just click accept.
    My other thought, I could probably setup the captive portal on my controller which has instructions for doing the captive portal with just an accept. Then I can add a link that forwards internal users to a login page to use their credentials to log in? Would that work?
  • 5.  RE: Guest Wireless only Accept Use Policy using Clearpass?
  • 6.  RE: Guest Wireless only Accept Use Policy using Clearpass?
    Posted Jun 13, 2014 04:40 PM
    Thanks that hasn't shown up in any of my searchs. It appears on first look to be just the thing I am looking for!
  • 7.  RE: Guest Wireless only Accept Use Policy using Clearpass?
