Guest wireless requesting aruba cert
  • 1.  Guest wireless requesting aruba cert
    Posted Apr 10, 2019 03:48 PM
    Just recently guest wireless requesting aruba cert even though we have no certs assigned to it or any other wireless network. The work around has been to accept the risk, so has anyone else have this issue, what caused it and is there a way to fix it
  • 2.  RE: Guest wireless requesting aruba cert
    Posted Apr 11, 2019 07:13 AM
    Thanks for sharing this.
    https://192-168-1-1ip.info/192-168-0-1/
  • 3.  RE: Guest wireless requesting aruba cert
    Posted Apr 11, 2019 09:02 AM
    Are you having the same issue? I assume you also do not have a solution to the issue?
  • 4.  RE: Guest wireless requesting aruba cert
    Posted May 10, 2019 09:25 AM
    it was never resolved
  • 5.  RE: Guest wireless requesting aruba cert
    MVP EXPERT
    Posted May 10, 2019 10:24 AM
    The certificate which was shipped with Aruba controllers was revoked, this might help answer some questions.
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Controllers/ta-p/275809
  • 6.  RE: Guest wireless requesting aruba cert
    Posted May 10, 2019 02:31 PM
    So I need to put my own or a 3rd party cert on it that isn't expired to fix it
  • 7.  RE: Guest wireless requesting aruba cert
    MVP EXPERT
    Posted May 23, 2019 06:57 AM
    Correct
  • 8.  RE: Guest wireless requesting aruba cert
    Posted May 10, 2019 02:00 AM
    Thank you for sharing this amazing article. Loved this post.
  • 9.  RE: Guest wireless requesting aruba cert
    why it was never resolved
