last person joined: 9 hours ago
Guest/MACtrac Registration Receipts and Expiration Warnings in bulk
  • 1.  Guest/MACtrac Registration Receipts and Expiration Warnings in bulk
    Posted Feb 10, 2021 04:47 PM
    Two questions (very similar to each other) related to the auto-smtp-email function in ClearPass Guest:
    1. I can bulk import up to 1,000 devices into mactrac as registered devices. Is there a way to make it so a single email is sent for the devices associated with the common email address of the registered devices?
    2. We have scenarios where individuals have registered 100s/1000s of devices. When these are due for expiration (likely all at a common date/time since they were registered in bulk), is there way to send a single email to the common email address associated with the registered devices?
    I appreciate your wisdom on this!
    Ryan Holland @ Ohio State
  • 2.  RE: Guest/MACtrac Registration Receipts and Expiration Warnings in bulk
    MVP GURU
    Posted Feb 11, 2021 08:10 AM
    Hi Ryan,
    For me, there is no option to send a single email...
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Guest/MACtrac Registration Receipts and Expiration Warnings in bulk
    Posted Feb 11, 2021 10:35 AM
    Not possible natively but could be done with the API.
    Tim C
  • 4.  RE: Guest/MACtrac Registration Receipts and Expiration Warnings in bulk
    MVP GURU
    Posted Feb 11, 2021 04:13 PM
    Yes API can be a solution (but need to check if all information are available with API)
  • 5.  RE: Guest/MACtrac Registration Receipts and Expiration Warnings in bulk
    Posted Feb 11, 2021 05:05 PM
    All the information required is available via the API...
    Tim C
