Guests connect but disconnect soon after
  • 1.  Guests connect but disconnect soon after
    Posted Nov 19, 2013 11:35 AM
    I'm hoping someone can help with this.
    I have a Dell Powerconnect W-620 controller running Aruba 6.1.3.7.
    I also have two AP's associated to this controller.
    I have already configured a network for LAN connection using EAP/RADIUS and now i'm trying to create a Guest SSID.
    I have followed what i thought was correct below but it seems the clients (Win7 Laptop and Android Phone) connect, get an IP from the Guest DHCP pool and then disconnect a few seconds afterward.
    Subsequent attempts to connect nearly always fail straight away without getting an IP.
    I have ran traces using NetMon on the laptop and not every time there are DHCP requests and you can see the IP given by the Guest VLAN IP to the laptop. If you run a quick 'ipconfig' it gets the IP ok but soon disconnects with no event logs.
    I have only added the pre-authentication role policies below as it doesn't hold its IP long enough to logon to the captive portal.
    Details:
    Guest VLAN created -
    ID=200 - IP 20.20.20.1 /24 - Not associated to any port
    Enabled src-NAT for this VLAN
    Inter-VLAN routing enabled
    DHCP -
    Enabled
    Guest_Pool1 -
    Default Router - 20.20.20.1
    Network - 20.20.20.0 /24
    Range - 20.20.20.6 - 20.20.20.254
    NAT Pools -
    dymanic-srcnat 0.0.0.0 - 0.0.0.0 - 0.0.0.0 for everything
    IP Routes -
    default gateway - 10.0.0.6 (IP of Firewall)
    No other routes
    Roles-
    Role - LM-Guest-guest-logon (pre authentication/captive portal)
    Policies-
    captiveportal
    source user Dest controller Service svc-https Action dst-nat 8081
    source user Dest any Service svc-http Action dst-nat 8080
    source user Dest any Service svc-https Action dst-nat 8081
    source user Dest any Service svc-http-proxy1 Action dst-nat 8088
    source user Dest any Service svc-http-proxy2 Action dst-nat 8088
    source user Dest any Service svc-http-proxy3 Action dst-nat 8088
    Guest-Logon-Access
    source any Dest any Service svc-dhcp Action permit
    source any Dest Public-DNS Service svc-dns Action src-nat pool dymanic-srcnat  (Public-DNS contains list of external DNS servers)
    Block-Internal-Networks
    source user Dest Internal-Networks Service any Action deny   ( Internal Networks lists IP ranges for internal networks)
  • 2.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 11:39 AM
    Can the user resolve DNS?
  • 3.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 11:43 AM
    Doesn't look like it.
    From what i can gather (since the connection only lasts a few seconds) it gets the DNS servers that i have assigned but it can't resolve www.google.com when pinging during  its time of having the IP.
  • 4.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 11:44 AM
    Resolving DNS is key to bring up the portal. Why are you source natting?
  • 5.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 11:47 AM
    Just going through an Aruba doc, albeit a little old but it gave me the fundamentals to set this up.
    I have no doubt there is something just configured incorrectly.
    Shall i just permit DNS ?
  • 6.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 11:48 AM
    Yes.
  • 7.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 11:53 AM
    Ok.
    I permitted DNS and it still dodn't work.
    Rule for Guest-Logon-Access
    any any svc-dhcp permit
    any public-dns svc-dns permit
  • 8.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 11:54 AM
    Can the IP address the client gets route to the internet? What is the default gateway?
  • 9.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 12:01 PM
    The client gets an IP 20.20.20.253
    This IP is not routable to the internet
    The VLAN is set directly on the controller.
    The controller is connected to a switch stack which doesn't have this VLAN 200 added to the trunk (not that i though this was necessary as i understood it used the address of the controller as its NAT)
    This switch then connects to a Firewall and then out to the internet.
    The default gateway on the controller is that of the Internal IP of the Firewall.
    I can understand if the client kept its IP but couldn't get to the Captive Portal but the clients are dropping the wireless connection within 10 seconds....slightly annoying me :-)
  • 10.  RE: Guests connect but disconnect soon after
    Posted Nov 19, 2013 12:23 PM
    You need to allow DHCP on your captive portal role too ?
    Make sure you have attached the captive portal profile to that role too ?
  • 11.  RE: Guests connect but disconnect soon after
    Posted Nov 20, 2013 04:10 AM
    I have just tried that this morning...same problem.
    It connects, client gets an IP, windows says it's connected but 'identifying' and then it disconnects.
    I'll attach some screen shots of the area the profile/roles are configured.
    Is there a way of getting logs of the connection from the controller or AP?
    I can't find a definitive answer of how to do this online.
  • 12.  RE: Guests connect but disconnect soon after
    Posted Nov 20, 2013 04:40 AM
    I may have found the problem.
    Looks like there is a WIPS profile on there to detect a rogue SSID not matching those in the list.
    The Guest SSID wasn't in the list !!!
    This must have been left over from a previous config.
    Captive Portal loads ok now and i can authenticate ok.
    Just trying to now sort why i can't access the internet even though i can resolve DNS :-)
