Wired Intelligent Edge
GUI Access
  • 1.  GUI Access
    Posted Jan 21, 2018 03:21 PM
    I am a new Aruba user. In the process of configuring my switch, I am no longer able to access my switch Web GUI. I can however access CLI and the switch via ArubaCentral. Any suggestions on how to restore web GUI access?
    Thanks in advance for any assistance that can be offered.
  • 2.  RE: GUI Access
    Posted Jan 21, 2018 04:35 PM
    By chance have  you disabled the feature by accident?
    Do the following:
    # show web-management
    Web Management - Server Configuration
    HTTP Access : Enabled
    HTTPS Access : Enabled
    SSL Port : 443
    Idle Timeout : 600 seconds
    Management URL : http://h17007.www1.hpe.com/device_help
    Support URL : https://www.hpe.com/us/en/networking.html
    User Interface : Improved
    OR
    HTTP Access : Disabled
    HTTPS Access : Disabled
    Is it enabled or disabled?
    if its disabled: configuration > web-managment
    If you didnt disable it, did you enable ip authorized-managers?
  • 3.  RE: GUI Access
    Posted Jan 22, 2018 12:52 PM
    I was able to resolve the connection issue. Apparently when a switch is linked to an Aruba Central subscription the web interface is disabled. After removing my switch from the subscription the web interface began working again.
