GUI issues
  • 1.  GUI issues
    Posted Dec 31, 2013 07:38 PM
    Hello - configuring a pair of 7210's. In the GUI, I'm having very weird issues using IE,Chrome and Firefox. Tried all three.
    Adding a simple radius server it cleared out the IP address but kept the server name. Had to fix it via CLI. Kept getting blanked when saving it via GUI.
    Configured some destination in the Firewall setting and they were being saved but not displayed in the GUI. If I add another it sometime displays based on sorting. There is no pagination....
    Going nuts as I've used the GUI to configure some 651s. Anyone seen this behavior? I also used private mode in browsers and cleared cache etc. no luck.
    #7210
  • 2.  RE: GUI issues
    Posted Dec 31, 2013 07:48 PM
    could be a firmware bug?
    which firmware you have got?
    Cheers
    Carlos
  • 3.  RE: GUI issues
    Posted Jan 01, 2014 10:15 AM
    Hi Carlos - this is from show ver:
    ArubaOS (MODEL: Aruba7210-US), Version 6.2.1.5
    Compiled on 2013-12-05 at 13:51:32 PST (build 41167) by p4build
    ROM: System Bootstrap, Version CPBoot 1.2.0.9 (build 35873)
    Built: 2012-10-24 13:51:09
    Built by: p4build@re_client_35873
  • 4.  RE: GUI issues
    Posted Jan 01, 2014 10:24 AM
    Hello
    There is something wrong with the 7210 tor with your computer then...
    I just added a radius server to a 3200 mx with that exact firmware and nothing wrong happened, it aded it correctly.   I used Firefox 26, and like a said an aruba 3200.
    I would advice you to create a support ticket with Aruba Tac
    Cheers
    Carlos
    #7210
