Running 6.4.3.7
CLI correctly shows 6 clients on a RAP
Airwave shows 3 clients on the same RAP
Controller GUI shows no clients on the RAP
Am I missing something? Is the GUI that inept? Anyone else see this?
You might have to open a tac case to get to the bottom of that. If you can reproduce it reliably, that would make it easier for engineering to know what is going on. Airwave will have a lag, depending on the protocol that you use to communicate between it and the controller, but the commandline and GUI of the controller should have the same number.
