Wired Intelligent Edge
Guide for aruba switchs
  • 1.  Guide for aruba switchs
    Posted Jun 18, 2019 12:11 PM
    Hi to everyone, this is my first post and came here because i have a big doubts. I adquire two switch and IAP 315 but when i try to configure throught web ui the thing it's a little strange for me. I try to configure a few vlan but when i try to check this and enter to the web ui again was not possible so i reset the switch. In the other switch i check the trunks and want to add ports to one trunk but the menu don't show anything.
    My plan it's to do a few vlan throught the switchs and put the IAP probably with his one vlan but with the little i move i have big doubts so i wanna ask if some knows or have a good guide to do the configuration from zero because i can't find in the internet a good reference. I have some knowledge of networks
    Thanks for your help.
    Greetings.
  • 2.  RE: Guide for aruba switchs
    Posted Jun 19, 2019 12:51 AM
    Hey hey glad you visited.
    What switch models are they and what code versions?
  • 3.  RE: Guide for aruba switchs
    Posted Jun 19, 2019 10:04 AM
    Hey #RINO thanks for your reply the switch are:
    Aruba 2930F 24G 4SFP
    Aruba 2590 24G POE
    And the IAP
    IAP 315
    THe idea is have the 2930F has a core and have some vlans to communicate between them and one vlan for the IAP. I try with the Web UI but i can get it. So if you know some videos or guide to follow or recommend use the CLI and where to start i can try.
    Greetings and thanks.
  • 4.  RE: Guide for aruba switchs
    Posted Jul 23, 2019 05:57 AM
    I would recommend using CLI.
    for the switches CLI Guide, you can download them from Aruba website, you can state the switch and the software version and then download the documentation
  • 5.  RE: Guide for aruba switchs
    Posted Jun 19, 2019 01:24 AM
    The Aruba OS switch CLI organised into diff contexts or levels.
    You can determine your current context from switch prompt, as below.
    context                                CLI prompt
    basic                                     switch>
     enable                                   switch #
    global configuration                  switch(config)#
    other commands context            switch (context(example(vlan-1))#
    Example:
    configured the vlan for untagged traffic on a port   vlan <vid> untagged <int-id-list>
    global configuration                               untagged <int-id-list>
    enable a port to carry tagged traffic for specefic vlans
    vlan <vid> tagged <int-id-list>
    global config context tagged <int-id-list>
    you want to see vlan after config
    show vlan
    show vlan port <int-id-list>
    save with write memory
