Guide to setting up RAP via USB LTE?
  • 1.  Guide to setting up RAP via USB LTE?
    Posted May 29, 2019 12:03 AM
    Hello all,
    I'm working on getting a RAP up and running over a USB LTE adapter.  I've got what should be a supported configuration - 205H, Inseego U730L, and I'm running 8.4.  However, I haven't had luck finding the process of convincing the RAP to use the LTE adapter for the uplink.  Is there any good guide someone could point met at?
    thanks!
  • 2.  RE: Guide to setting up RAP via USB LTE?
    Posted Feb 16, 2022 01:54 PM
    Did you find a usb modem that is tested and works?
    Thank you
    Nils
    Nils Lau
    Nova Southeastern University
