Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
  • 1.  Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 01, 2014 12:37 PM
    I am Looking to see if anyone has depolyed IAP225s in a warehouse or loby with 30' ceilings without antennas
  • 2.  RE: Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 01, 2014 12:42 PM
    30' should work fine.  The IAP-225 has internal antennas and have a downtilt bias and would achieve a similar result to an IAP-224 with an external downtilt.such as the ANT-16.
  • 3.  RE: Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 01, 2014 01:02 PM
    If the strength isnt all there can we add antennas to help?
  • 4.  RE: Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 01, 2014 01:20 PM
    The IAP-225 has internal antennas only.  I know there have been warehouse deployments with APs at 30 - 40' feet.
    If you want to go with external antennas you need an IAP-224 then select the appropriate 3x3 MIMO antenna from the price-list.
  • 5.  RE: Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 01, 2014 01:37 PM
    Yeah just pulled one out no place to add a antenne on those, Im trying to avoid changing to the 224s,
    The deployments your talking of what type of APs were they?
  • 6.  RE: Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 01, 2014 01:40 PM
    I know mainly of AP-105's.  The AP-225 has better receive sensitivity than the 105 so it should perform as well or better.
  • 7.  RE: Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 01, 2014 07:19 PM
    We use 105's at 35-45 feet with mostly no issues, the 225s shoudl be great at 30
  • 8.  RE: Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 01, 2014 07:23 PM
    We have quite a few deployments of IAP225s in Warehouses at 30 to 35 feet.
  • 9.  RE: Guys question came up, will an IAP225 work in an environment with 30' ceilings without any antenna's
    Posted Aug 05, 2014 08:49 AM
    I have a setup in a warehouse with aruba 225 and 10 to 12 meters (30 feet) to the construction rafters, i have perfect coverage and a lots of clients on B/G/N and some on AC. the warehouse is 15000 m2 (161458.65ft²)and i'm only having 9 accesspoints...... and the coverage Perfect!
    /Niklas
