gvrp
  • 1.  gvrp
    Posted May 17, 2017 11:05 AM
    Is there a way to enable gvrp on aps (205h and 215)? I have 802.1x sending users to certain vlans (bridge mode). The only way it is working is for me to manually tag the ap switch port for the vlan. Would be awesome if gvrp could do this for me.
    My setup
    7210 in data center
    300+ 205h / 215 in 5 locations
    ArubaOS 6.4.3.8
    Tom
  • 2.  RE: gvrp
    Posted May 17, 2017 11:10 AM
    what is gvrp?
    The user VLAN for each SSID needs to be trunked to each access point in a distributed setup like Instant.
  • 3.  RE: gvrp
    Posted May 17, 2017 11:15 AM
    gvrp
    http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/RA/15-18/5998-8155_ra-2620_atmg/content/ch02.html
    gvrp would do auto tagging so I would not have to manually do 300+ aps
    Tom
  • 4.  RE: gvrp
    Posted May 17, 2017 11:27 AM
    Tom,
    If you have 300+ APs, you should consider a controller, instead. You would only have to tag the VLANs on a single interface between the controller and a layer 3 switch..
  • 5.  RE: gvrp
    Posted May 17, 2017 11:40 AM
    I do have controller
    7210 in data center
    Dont follow this
    I have all hp switching so will use their 802.1q commands
    Ap 205h untagged vlan 110 (native vlan for the classroom the ap is in)
    When a student logs in I want to drop them in vlan 72
    When a teacher logs in I want to drop them in vlan 75
    This works when I
    vlan 72 tag port_of ap
    vlan 75 tag port_of_ap
    If the ap did gvrp, the switch would see vlan 72 traffic and auto tag the port.  Or, am I missing something?
    Tom
  • 6.  RE: gvrp
    Posted May 17, 2017 11:55 AM
    So you have a single controller in the datacenter and all user traffic will be bridged to the local network through the AP, or will all user traffic be tunneled to the controller?
  • 7.  RE: gvrp
    Posted May 18, 2017 09:41 AM
    Bridged otherwise I would tag at the controller??/
    Tom
  • 8.  RE: gvrp
    Posted May 18, 2017 10:07 AM
    I don't know anything about GVRP and maybe someone should chime in.
    But from a design perspective:
    If none of your APs tunnel any user traffic back to the controller, the design decision should be instead to have Instant AP clusters at those locations, instead of having to send back VLANs per site in a controller-based design....
  • 9.  RE: gvrp
    Posted May 18, 2017 10:22 AM
    Some will tunnel (guest).
    I agree I should have been sold IAP versions. Don't see why any other version is sold. IAP can do them all (campus, rap, iap).
    This is what I want to do. Looks like iap only???
    http://community.arubanetworks.com/t5/Wired-Networks/Pre-provisioning-VLAN-in-MAS-using-GVRP/ta-p/166292
    Tom
