Has anyone been able to successfully authenticate the admin access to Cisco ACS v5 using either TACACS or RADIUS?
Thanks.
http://hpnetworkers.blogspot.com/2011/05/hp-series-h3c-comware-radius.html
This likely has your answer!
Thanks for the link. I've got it working with Telnet but I have one small problem - it doesn't work unless the username also exists in the switch config. Is this correct? Can it not be done without the username being in the config?
