HA fast failover - bridge mode SSID
  • 1.  HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 05:38 PM
    I've noted that this feature doesn't support 'Campus AP's running in bridge mode'.
    Does this mean there can be no bridged SSIDs on the AP full stop?
    I also noticed on one of the solution guides that it would be supported from 6.4.1 - is there any validity to this statement?
  • 2.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 05:58 PM
    If it is in the release notes or documents, it is supported.  It was not supported initially.
  • 3.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 06:39 PM
    To completely answer  your question, it just means that before ArubaOS 6.4.1 bridged SSIDs will not work on the failover controller if HA is configured.  The previous version of failover, lms and backup lms-ip will work just fine with bridged SSIDs.
  • 4.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 06:48 PM
    Hmmm seems like the docs need to be updated - most still say bridged mode is unsupported...
    From 6.4.2.4 release notes:
    AP Fast Failover Support for Bridge-mode Virtual AP High Availability (HA) support for bridge mode in Campus AP is introduced in ArubaOS 6.4.1.0. In previous versions of ArubaOS the fast failover feature for Campus AP was supported using tunnel or decrypt mode. Now support has been extended to bridge mode as well.
  • 5.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 07:04 PM
    Do you mind posting the link to the document for ArubaOS 6.4.1.x and above that says it is not supported?
    EDIT:
    "AP Fast Failover Support for Bridge-mode Virtual AP High Availability (HA) support for bridge mode in Campus AP is introduced in ArubaOS 6.4.1.0. In previous versions of ArubaOS the fast failover feature for Campus AP was supported using tunnel or decrypt mode. Now support has been extended to bridge mode as well." --  This means that in versions previous to 6.4.1.0,. it was not supported.  It does not mean that previous to 6.4.2.4 it was not supported...
  • 6.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 07:07 PM
    Here is one that is a little misleading:
    https://ase.arubanetworks.com/solutions/id/53
  • 7.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 07:09 PM
    Here is what it says on that page (unless I misread it):
    "AP Fast Failover feature supports CAPs in tunnel and de-tunnel forwarding mode. CAP in bridge mode will be supported from AOS 6.4.1 onwards."
    That means it is supported from 6.4.1 onwards.  Is that the wrong part?
  • 8.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 07:11 PM
    Its slightly misleading that the article mentions it was deployed using 6.4.2.6. which is after 6.4.1..
  • 9.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 07:37 PM
    So the text should say that bridged mode IS supported instead of WILL BE supported?
    Will that work?
  • 10.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 07:40 PM
    Yea definitely - a VRD would be useful at some point too :)
  • 11.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 07:46 PM
    The HA instructions could fit on one single-spaced page.  It might not be a good candidate for a VRD.
  • 12.  RE: HA fast failover - bridge mode SSID
    Posted Apr 03, 2016 07:48 PM
    Fair enough - could be absorbed into one of the other VRDs though? They don't appear to mention it.
